First post, by Luke6493
...or is is it just for running games under the Windows VDM? If so, is there a version of this patch that works for DosBox? Using it under DosBox only generates a message that, "this program will not work in DOS mode".
Reply 1 of 3, by Gamecollector
For the start - why do you need cli2nop patch if you are already using DOSBox? All "Build" games are working perfectly in DOSBox w/o any cli2nop, nolfb etc...
Reply 2 of 3, by Luke6493
What about the echo crash fix? It's purely a game specific patch and not related to VDM or DosBox.
Reply 3 of 3, by leileilol
You won't need the echo crash fix or CLI2NOP or NOLFB. DOSBox emulates an ISA sound card properly which gets along with the echo effects of the Apogee Sound System used in ROTT, Duke3D, Blood, Shadow Warrior.
Enjoy your BUILD games with intended behavior!
