First post, by feipoa
Take a look at this odd 486 board on eBay,
http://www.ebay.com/itm/Itox-Motherboard-g486 … c-/300734194334
The PCI slot is shared with an 8-bit ISA slot. And there's only 1 PCI slot. This is likely one of those industrial 486 boards. It also uses a VIA chipset; weren't those buggy with PCI slots?
I wouldn't mind seeing a Speedsys screen capture of one of these.
    69.17 KiB
Reply 1 of 5, by Tetrium
I wonder if one can disable the onboard video (it has onboard according to the advertisement on Ebay).
It does look like it's one of those industrial boards.
My retro rigs (old topic)
Report spammers here!
Reply 3 of 5, by sliderider
I wonder what PCI version that slot is. You might be able to build a 486 system that is able to use a more recent PCI video card than the ones that were actually made during the 486 era. It might be worth toying around with if you could use a V3 or later card in that slot.
Reply 5 of 5, by feipoa
We know that a Voodoo3 will work in SiS socket 3 boards. It will not work in UMC socket 3 boards. Has anyone tried a Voodoo3 in an ALi, OPTI, or Intel socket 3?
