First post, by PhaytalError
Hey everybody!
Just wondering, in what year of gaming would absolutely max out on a Pentium III 700Mhz or Pentium III 1.4Ghz with a Voodoo2 or Voodoo 3?
By max out I mean highest graphic settings but still running at a frame rate of 25-30FPS.
Thanks in advance! 😁
Please note: 25 - 30FPS is considered playable, in my humble opinion.
DOS Gaming System: MS-DOS, AMD K6-III+ 400/ATZ@600Mhz, ASUS P5A v1.04 Motherboard, 32 MB RAM, 17" CRT monitor, Diamond Stealth 64 3000 4mb PCI, SB16 [CT1770], Roland MT-32 & Roland SC-55, 40GB Hard Drive, 3.5" Floppy Drive.
Reply 1 of 13, by leileilol
Obviously with a Voodoo2/3 you can't run on the highest for anything after 1999+ due to the sudden rise of 512x512's, 32-bit textures and DXT1
Reply 2 of 13, by sliderider
You wouldn't use a V2/V3 with that system. the Voodoo 4/5 and Pentium III came out at close to the same time, so you would want to use one of those because they support the features that LeiLei mentioned above. Voodoo 2 would be especially bad because when you pair those with a really fast CPU, they heat up and a V4/5 runs circles around V2 SLi anyway.
And 30fps really isn't playable because as soon as the CPU or video card get busy, your frame rate will dip into slideshow territory. I would consider 30fps to be the minimum with 50+ being playable.
Reply 3 of 13, by F2bnp
30fps is nice, as long as it is constant and doesn't dip lower than 20 fps at any given moment. Voodoo 2 and 3 were great all the way to early 2000. Around that time came the sudden rise as leileilol noted of a lot demanding features.
The Pentium 3 Tualatin 1.4Ghz should have been fine all the way to 2003 perhaps even early 2004.
Reply 4 of 13, by leileilol
I was actually judging off the 700mhz version. The PIII 1.4GHz could do up to 2005 IMO, the SSE gives it a little more lifetime to run games like Quake 4, Serious Sam 2, Battlefield 2, Republic Commando and maybe even Half-Life 2 Episode 1. AGP Radeon9x00 of course, considering the Voodoo2/3 would be bottlenecking it down to 2000 again.
Reply 5 of 13, by F2bnp
Well, Half-Life 2 vanilla with a 6600GT was giving me around 20fps at Medium Details and 1280x1024 if I'm not mistaken which isn't all that playable. I don't imagine Doom III and Quake 4 would be any better.
I'll have to try Far Cry and see how it fares though!
Reply 6 of 13, by [GPUT]Carsten
I played on my P3-S 1.4 with a Geforce 6800 vanilla through 2005. But certainly not all maxed out and having constant 20-30 fps, unfortunately. 😀
Reply 7 of 13, by jmrydholm
My Quantum3d Graphite runs a PIII at 733MhZ with a Voodoo 5 5500 (AGP version) for graphics, Windows 2000 Professional. My main problem is it only has 128MB of very slow RAM installed. I could use at least 256 for some of my games. I'm keeping that system strictly for OpenGL/Glide games, though Klingon Academy runs *perfectly* even though it's a DirectX game. It's the first system I've ever had KA run well on in years! Also, Messiah by Shiny Games.
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
Reply 8 of 13, by leileilol
Klingon Academy's an odd CPU hog. It also runs the same on a PCX2 as it does on a Voodoo2.
Reply 9 of 13, by jmrydholm
Another Trek title on myPIII system I tried was New Worlds. On most newer platforms, I always had tiny, corrupted text.
Reply 10 of 13, by sgt76
I've been playing with my Tualatin 1.6ghz rig + GF3/ V2 SLI rig the last couple of days, and I would say the answer to this question in 2013 at least, given our own increased expectations and standards, would be 2001. Anything 2002 onwards, I would rather entrust to an Athlon XP/64 or P4 system. For instance, WC3 takes forever to install on my P3 rig.
Reply 11 of 13, by Standard Def Steve
2004 for me. My 1.59GHz PIII+9800Pro setup handles nearly all of my 2004 games just fine at 1280x960 or 1440x900. I never bother with AA, of course. There's something insanely great about replaying games that used to struggle on my pricey P4-1800/Radeon 9500Pro on a PIII I built for $40...at twice the frame rate. 😀
2005 and newer games go on the 4.6GHz i7.
Reply 12 of 13, by SPBHM
I agree on 2004,
2005 was already SM3.0, dual core and the preparation for the Xbox 360...
but 2004 was when Doom 3, Far Cry and Half Life 2 were the best, and these games can be played on a fast Pentium 3, obviously a high end CPU from 2004 would do better (Athlon 64)
Reply 13 of 13, by Scylla
I'd also say 2004 at best fot he Tualatin 1.4 GHz.
It was a monster of a computer back in the day, I remember quite well the soaring prices of these CPUs on eBay and elsewhere and dozens of enthusiasts keep saying that a P3 1.4 GHz. would hold its own against a 2.0 GHz. P4 in almost any real world scenario. But, for me, a lot of hardware died when Doom 3 was released, even if I have never liked the game itself, but its graphics were absolutely thrilling. My recollection of those years is that no one had ever seen a true DirectX 9 game until Doom 3 (although being an id game it probably uses more OpenGL than DirectX) and that my GeForce4 Ti struggled to move it while the newer Radeon 9700/9800 Pro cards were playing it with more impressive visuals and faster speeds.
Yes, I'd definitely state 2004 as the final year where a P3 Tualatin based gaming rig made sense.
