First post, by Great Hierophant
I was facing a puzzling problem with my 486. In The Lost Files of Sherlock Holmes, Case of the Serrated Scalpel, the introductory sequence where Holmes and Watson are talking always froze, requiring a restart. The usual area was just as Watson was reading Lestrade's note. I thought it was a speed issue, so I tried every slowdown feature I could think of, but nothing worked.
Then I decided to look at the manual, which was unhelpful. But I later thought that the reference card may have something to help me, and it did.
Note: If you are using DOS 5’s EMM386 expanded memory manager, and want to hear the digitized speech in Holmes, the default DMA […]
setting of 16 will have to be increased. Support for EMM386 can be
achieved by adding the parameter d=40 after the EMM386 entry in the
config.sys file as shown here:
device=c:\dos\emm386.exe d=40
See your DOS manual for information about editing files.
Since I was using MS-DOS 5.00, this attracted my attention. When I added that line, the intro finally finished without difficulty. There are two other talking sequences in the game, and a crash at either of them would be very annoying.
