First post, by Volksjager
I believe I have either a CT3990 or CT3980 and on my machine the digital sound and most FM sounds work fine but for certain games that use Ad Lib exclusively (Secret Weapons of the Luftwaffe, e.g.) the music becomes an unbearable screech. I am not sure if this has anything to do with the -5 volts power rail (probably not since I recall my BIOS showing it correctly) or hardware problem (some set up programs could not detect the Ad Lib.) What further tests should I perform and had anyone else had similar problems? Thanks.
Reply 2 of 7, by Volksjager
The machine is Pentium 4 2.8 GHZ. I doubt it is a speed issue since a AWE64 works on a machine with similar configuration and most music works. I am using QEMM386 so I am not sure if that affects anything.
Reply 3 of 7, by 5u3
Find out what CT number your card is, as this could be important. CT3980 has the equivalent of a real OPL3, but the CT3990 has the CQM chip instead.
I'd say it's speed issues as well. I'm surprised SWotL even runs on a P4.
Reply 4 of 7, by Great Hierophant
Don't forget that SWoTL was programmed to run on an Adlib card. The YM3812 OPL2 chip on that board required delays on an XT, nevermind a P4.
Reply 5 of 7, by Mau1wurf1977
WOW!
Try these trick:
Go into the BIOS and see if there is an option to disable L1 cache.
Reply 6 of 7, by Volksjager
Thanks for the hints so far. I will try them. Is there anyway to find out the device without opening the computer (which I will be doing a bit later)? I think it may have that CSP chip installed.
A similar problem occurs with the game Command HQ. Both SWOTL and CHQ work with VDMS on this computer as well as with AWE64 and another AWE32 (without CSP) on another Pentium 4.
Reply 7 of 7, by AdamP
Sounds like it is a speed issue judging by this.
