First post, by hibye
hibye
Offline
I was trying to place the drivers linked to in this tutorial like instructed. But I placed them in the wrong folder by mistake. So I tried to move them and it took forever, and in the end never moving. I tried to delete them with similar results. I deleted them individually, narrowing it down to two files that can't be moved, deleted, modified or renamed: vgasys.fon and vga.oem.fon. I've even tried removing them in safe mode with no avail. How do I get rid of them?
EDIT: Never mind. I did a System Restore and the problem solved itself.
