dosbox 0.74: Need help getting video sequences to play in Privateer 2 The Darkening
First post, by drokmed
Hi all, my first post here.
I got the game to work (Privateer 2 The Darkening), but none of the video sequences will play, meaning I lose the plot line. Everything else works, space flight mode, audio, even the joystick works correctly (Logitech Extreme 3D Pro).
Upon starting the game, the screen flickers, shows snow/static, obviously trying to play the opening video sequences. I can escape past that, and it takes me to the game beginning scene, in the bar. Whenever I click on a person to start the dialogue, again, the screen flickers as it tries to play a video sequence, then returns to normal screen, and allows me to click on an option.
All other ingame features are working correctly. I can buy/outfit a ship, launch and fly around.
I have been tweaking the config file, playing with all the settings. I had to slow the game down, to get the joystick to stop twitching. Other than that, no luck with the videos playing.
I'm attaching my config file, for your review.
My ASUS laptop specs:
ASUS Notebook G73Jh Series
Intel Core i7 Q740 @ 1.73GHz
6 GB RAM
Windows 7 Home Premium 64-bit
Service Pack 1, all updates installed
I'm using one (tried two different ones actually just in case) of the downloadable warez copies of the game, no cd required. I used to have the original, bought it long time ago, but no clue where it is. They got my money, so I feel fine using a "copy", I don't see any conflict, they got my money already. All flames > /dev/null
I welcome any suggestions. I have read through the dosbox manual, but didn't find anything in it that helped.
Thanks
    dosboxPRIV.conf
    7.33 KiB
    104 downloads
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
the copy, which is still illegal though, might be without videos, as that is common with cdrips. Which is one of the main reasons we don't want to support warez.
Maybe check the size of the video files.
Anyway that is all the help you can get
complaints > /dev/null
Water flows down the stream
