First post, by pmcp
pmcp
Offline
Hello.
I'm trying to run 2 instances of dosbox at the same time but when I switch focus from one to the other the sound cuts out. Is there a way to get around this? I don't think it's relevant but in case it helps I'm running Fasttracker 2, but it cuts out before I've done anything in the second instance.
Thanks,
Pete
