First post, by GangreneTVP
I would like to have the dosbox window open in a larger size. I have set scaler = advinterp3x(from 2x... it's better) , but I'd like to make it even bigger without it being full screen. Is there some kind of way I could set it to advinterp4x or 5x? I already tried it unsuccessfully, but maybe there is alternate work around I could use?!? If it can make it grow to full screen and 2x and 3x I'm hoping I can make it even larger despite not having a built in advinterp4x or 5x.
Why? The background is... Basically I'm using Fraps to make some recordings and it doesn't want to work when dosbox is on full screen, but it will record when it is in a window... So I'd like to make the window as large as possible without being full screen. So I can get the best recordings for my audience.
Thanks in advance!
Matt
