First post, by lucky7456969
Hello,
I am baffled by this for a while.
I need a database server to be set up in a virtual machine
I use VirtualPC, but I borrow the virtual host-only adapter by virtualbox
In virtual box, I
1) Use host only adapter 192.168.56.10
2) Use subnet 255.255.255.0
3) Use DHCP server set as my router/gateway for example 192.168.0.1
I used to get it right one time, no need to bridge, but this time I just can't get it right
4) In my virtual host adapter setup in control panel,
I use gateway and DNS as my router/gateway for example 192.168.0.1
I uncheck LMHOST and Netbios over TCP/IP
5) I disable the firewall for virtualbox and virtualpc
In my guest,
I use DHCP to grab ip for this VM. The upper part is left blank
and I set DNS as 192.168.0.1 at the bottom part.
Sometimes the guest nic can ping to the virtual host-only adapter,
but not up to the gateway, therefore no internet and no access to
other machines. One of my major concerns is to show this machine in my host window explorer. I tried various methods but still can't get it right.
Anyone knows of a good guide for me to set this up properly?
I tried youtube and google, but no good.
Thanks
Jack
Reply 1 of 6, by TheMAN
I don't mess with VirtualPC much because I prefer to use VMware as it is much easier to configure and FASTER.... plus it is FREE (the player version).... so I can't help you here really except to suggest you to try VMware Player
VMware clients allow 3 different types of network connectivity... bridged, NAT, or host-only... all easily configurable from within each guest's settings
VMware also allows advanced customization, such as modified BIOS ROMs, host SCSI port redirection, etc
you can easily convert to/from a virtual PC image to a VMware one
if you use VMware workstation, it even allows fine tune of the VMware network adapters installed on the host system
Reply 2 of 6, by Reckless
I now use VirtualBox exclusively after using Virtual PC until the Windows 7 version was released. It was very poor at networking in particular that I got fed up and binned it 😀 My advice, take a copy of the VHD and load it into VirtualBox directly and see if it's better. VMWare is also a good option though I prefer VB for home and ESX/VSphere at work 😀
Does your DB server need to accessible on your network or just from the VM host machine? I run a few servers for testing purposes and run the Virtualbox network in NAT mode. Each machine can see the Internet but don't allow access in except from the host on certain ports. The guest has a few NAT rules configured (port 8080 for example) by way of the vbvoxmanage modifyvm command. I add a local entry in my hosts file if I need to access the machine via name. For example, a test TFS server is running on a guest. From my Visual Studio client I simply add the TFS server by name and if the guest is running the Team Explorer component will connect to the server via the port redirection.
There are a number of options open to you using VirtualBox: http://www.virtualbox.org/manual/ch06.html
Reply 3 of 6, by TheMAN
I like VMware over VirtualBox because it's more easier to configure and customize... but VirtualBox works better with retro OS's and it has a "real" SB16 emulation... I used it to test the real SB16 drivers install disks, and they worked!
Reply 4 of 6, by leileilol
I only use VirtualBox to run XP, for the occassional Microsoft Sam, and testing of fishy suspicious programs that may contain nagware (like every modern shareware).
I do use Virtual PC for networking though 😜
long live PCem
Reply 5 of 6, by lucky7456969
When I virtualize Windows 98 SE on VirtualBox, the VBox Additions are unable to be installed.
I installed the x86 one. I setup ICH9 for Northbridge and some old hardware to a bear minimum My vbox 4.1.8
Any help would be greatly appreciated!
Thanks
Jack
Reply 6 of 6, by TheMAN
use vmware player 3.1.5... it will have those guest OS additions you need (virtualpc might too)
virtualbox does not have them and I don't think it ever will
