ACT 5.6 error.
First post, by Gamecollector
Windows Xp Sp3 32-bit.
I installed Application Compatibility Toolkit 5.6.
The trouble is - if I try to expand "system database (32-bit)/applications" database - I have the "This version of the Compatibility Administrator only supports opening 32-bit compatibility (.sdb) databases. Please use the Compatibility Administrator (64-bit) tool to open 64-bit compatibility databases.", then "Compatibility Administrator was not able to open database: '%s'" messages.
The question is - this is the ACT 5.6 error in 32-bit support and I need the version 5.5? Or I'm doing something wrong?
Tnx.
Reply 1 of 1, by filipetolhuizen
Yes, I had the same problem. It works fine in Win7 32 bits, but has this problem in XP. I'd stay with version 5.5 on XP OS.
