First post, by sarah07
i am having a problem mounting a folder..i have edited and added the mount lines at the bottom of the dosbox conf notepad..but it says illegal command
🙁 please help...
Reply 1 of 5, by MaxWar
Can you provide more details such as "what command" exactly did you enter.
And does the same command works when you type it directly in dosbox?
Edit: Just realized this was my post #486
Gotta go play some old game to celebrate 😁
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
Reply 2 of 5, by sarah07
i am adding
mount c c:\db4
c:
dbase.exe
then saved it in the conf file but when i opened the dosbox
it says
z:\>mount c c:\db4
Drive c is mounted as local directory c:\db4\
Z:\>c:
c:\dbase.exe
illegal command c: dbase.exe
it does the same when i type it directly in dosbox..🙁
please help me..thanks for the reply..😀
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Mounting folder is obviously working, just that the exe is not there. Check where that really is on your computer and provide a screenshot of explorer showing the file
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 5, by sarah07
yes it is in the computer..i am just confused that when i put db4\dbase.exe it works....but how can that be if the folder has been mounted as the C: drive.?
Reply 5 of 5, by robertmo
mount c c:\db4
cd db4
c:
dbase.exe
you can always type "dir" in dosbox
