First post, by Kreshna Aryaguna Nurzaman
So, regarding this thread, I purchased Griffin Powermate several months ago, but haven't got the chance to test the thing until recently.
It works pretty well. You can map the rotation to mouse axis, key presses (it's called SendKey method), and certain basic functions like volume control. I map the rotation to left-right keyboard cursor keys in Star Control 2 remake, and ship rotational control feels more intuitive using the device.
However, the keyboard mapping doesn't work in DOSBOX. I works in everything else I tested it, including Notepad, but in DOSBOX, the SendKey method doesn't work.
Oddly enough, my CH HOTAS' keyboard emulation works in DOSBOX, and so does my Logitech joysticks (using Logitech Profiler). Only Griffin Powermate's keyboard emulation doesn't work in DOSBOX. However, Powermate mouse axis emulation works fine.
I just wonder, does Griffin Powermate use certain keyboard emulation method that doesn't work with certain application? And what kind of keyboard emulation method that doesn't work in DOSBOX?
I have contacted Griffin Technology technical support, but haven't got any reply.
Reply 2 of 9, by Kreshna Aryaguna Nurzaman
Davros wrote:
unplug your keyboard (leave the powermate connected)
start dosbox see if the thing works then
I'm using laptop, but I'll try it with the desktop PC at my office. What makes you suspect the keyboard, by the way? Just curious.
Oh, and thanks for the suggestion, I'll give it a try.
Reply 3 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
try with any other SDL based program. ScummVM or Exult for example. Could be an SDL issue...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 9, by Kreshna Aryaguna Nurzaman
I see. Will do.
Kreshna Aryaguna Nurzaman.
Reply 6 of 9, by Kreshna Aryaguna Nurzaman
Griffin tech support sent me the Windows SDK. Unfortunately I ain't no programmer. How do we discover its incompatibility with DOSBOX from the zip I attached?
    PowerMate SDK Windows.zip
    249.25 KiB
    137 downloads
Reply 7 of 9, by Dominus
DOSBox Moderator
first test as I told you
Reply 8 of 9, by Kreshna Aryaguna Nurzaman
Will do, will download a SCUMMV game and test it, will be back with update.
Reply 9 of 9, by Kreshna Aryaguna Nurzaman
Ah,
I haven't got the chance to test PowerMate with SCUMMVM, but I tried windib. Guess what, it works! 😀
Wonder why it didn't work without windib option.
