First post, by exofreeze
I am attempting to play the game UnReal World, which is a survival rpg. Versions 1.0-2.2 were for dos and distributed via shareware.
v1.0 is available at the main site:
http://material.lahnarecords.fi/urw/urw100b-full.zip
I can't seem to find any dos versions after this.
When I start v1.00b in 0.74, the title screen pops up and gives me the starting options assigned to F1-F4. However, hitting these keys does nothing. I have tried every key on the keyboard.
I have also tried:
changing core to normal
cputype to 386, 386_prefetch
turning off upper memory options
running w/ loadfix
Same result across the board. The title animates, but no key presses are read.
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Try increasing cycles. On my system it starts responding to keys at ~3750 cycles.
Reply 2 of 2, by exofreeze
that worked. thank you. I've never seen an issue like this before.
