First post, by bichuch
I use some old text-mode DOS programs. They are working fine in 50-line VGA-text. In the past (console window under WinXP) I surrounded them with "mode con lines=50" and "mode con lines=25" pairs in their .BAT-files and console window changed it's heighth as expected. But now, under W7-x64, there are no "mode" command in the DOSBox. And font becomes very ugly after program's switching into 50-lines mode, because of constant physical size of the DOSBox window.
Is there any method for height of text-mode window changing?
