First post, by danoon
danoon
Offline
svn 3666 changed numRec from Bit16u to Bit16u*, but the statement below "if (numRec>0)" was not changed to "if (numRec && *numRec>0)". This will prevent the path of passing in a pointer holding 0 from working.
dos/dos_files.cppBit8u DOS_FCBRandomWrite(Bit16u seg,Bit16u offset,Bit16u * numRec,bool restore) {/* see FCB_RandomRead */DOS_FCB fcb(seg,offset);Bit32u random;Bit16u old_block=0;Bit8u old_rec=0;Bit8u error=0;Bit16u count;/* Set the correct record from the random data */fcb.GetRandom(random);fcb.SetRecord((Bit16u)(random / 128),(Bit8u)(random & 127));if (restore) fcb.GetRecord(old_block,old_rec);if (numRec>0) {/* Write records */for (count=0; count<*numRec; count++) {error = DOS_FCBWrite(seg,offset,count);// dos_fcbwrite return 0 false when true...if (error!=FCB_SUCCESS) break;}*numRec=count;} else {DOS_FCBIncreaseSize(seg,offset);}
