The install on the disc simply copied 3 files over to a THBDATA directory, and then created a THBSAVE directory. Then it created a SE directory populated with a CFG file that contianed the following:
[Setup]
Part1=C:\THBDATA\THB.001
Part2=C:\THBDATA\THB.002
Part3=C:\THBDATA\THB.003
CdRom=D
SaveDir=C:\thbsave\
[DigiSound]
CardType=2
Quality=3
Port=220
Irq=7
[FmSound]
CardType=3
Running THB solo, without any of the installed files, gives me the same interrupt error.
I just tried the latest SVN build and got the same error.
Just checked my cue file, and it has no audio tracks, so I doubt it is something to do with the timing being wrong as a few games have shown in the past.
To verify it was not my conf, I just went and grabbed the 0.74 conf file from my appdata folder, copied it over and just appended my mount commands to the end:
mount c .\games\TheHidde
imgmount d .\games\TheHidde\cd\thb.cue -t cdrom
I then launched this, changed to the d:, and tried to run THB and it hung in the same manner.
As far as I can tell, this means that either my particular version of the game causes this problem, or dosbox has a problem with core i7 processors, as that is still the single link between those who are having problems playing Chasm and those who say it works fine.
The dates of the files on my cd are 8/17/1994, with thb.exe being 8/24/1994.
