First post, by danoon
danoon
Offline
bios_disk.c
static Bitu INT13_DiskHandler(void) {...case 0x08: /* Get drive parameters */if(driveInactive(drivenum)) {last_status = 0x07;reg_ah = last_status;CALLBACK_SCF(true);return CBRET_NONE;}reg_ax = 0x00;reg_bl = imageDiskList[drivenum]->GetBiosType();
Looking at specs, and the other cases in int13, I believe reg_ax = 0x00 should be reg_ah = 0x00
This doesn't fix any bugs that I know of, but I was looking around this part of the code and noticed it.
