First post, by GreatDragon
How to run Pandemonium 1 on 3DFX Voodoo 3 ?
Reply 2 of 14, by GreatDragon
I can not select 3DFX videocard , when install game ,
attached photos
If copy pandy3.exe with pandy3.bat in folder game ,
run pandy3.exe or pandy3.bat , game not working
    5.28 KiB
Reply 3 of 14, by Gamecollector
The easiest (only?) way - use good DX9 videocard and nGlide as the wrapper.
The trouble is - glide.dll and sst1init.dll are very old. And are working correctly with Voodoo1 only. Of course Voodoo3 isn't detected.
Is software version (pandy.exe) working?
Try to run 3dfx version (pandy3.exe) with the sst variables for Mechwarriors 2: 31st century combat:
set SST_GRXCLK=90
set SST_FT_CLK_DEL=0x4
set SST_TF0_CLK_DEL=0x6
set SST_TF1_CLK_DEL=0x6
set SST_VIN_CLKDEL=0x1
set SST_VOUT_CLKDEL=0x0
set SST_TMUMEM_SIZE=2
Reply 4 of 14, by GreatDragon
Need for Windows 98
>Is software version (pandy.exe) working ?
Yes
>set SST_GRXCLK=90
Working only in Direct Draw , no Glide ((
Reply 5 of 14, by Gamecollector
Err, pandy3.exe is containing glide version only. So, if the game is working from pandy3.exe - this is the glide version.
The test method is - in-game pause menu (Esc). Glide version - black screen with the standard menu string.
Reply 7 of 14, by GreatDragon
Reinstalled Windows 98
With
pandy3.bat
set SST_GRXCLK=90
pandy3.exe
If run pandy3.bat , back in Windows 98 ,
not working Pandemonium on Voodoo 3
Reply 9 of 14, by GreatDragon
did you install the non glide version then copy over pandy3.bat and pandy3.exe ?
Yes
And change in pandy3.bat
set SST_GRXCLK=90
pandy3.exe
Reply 10 of 14, by Jorpho
attached photos
You can try to force it using Windows Enabler, if you think that might help.
Reply 11 of 14, by Gamecollector
Jorpho: The installer is using sst1init.dll from the cd to detect Voodoo card. So - this option will be active only for the real Voodoo1. You must copy the glide version manually (pandy3.exe -> pandy.exe, pandy3.bat -> pandemonium.bat).
Unfortunately, it looks like the glide 2.1.1 isn't working with anything except Voodoo1... 🙁
Reply 12 of 14, by Jorpho
Enabler overrides any standard Windows dialog box settings and lets you select an option even if a program has otherwise already determined that the option should be greyed out. (Obviously this is not always a good idea.) I was thinking that maybe in addition from copying the files, the installer also toggles some setting hidden somewhere that is required to enable Glide support when that option is selected. Just a thought.
Reply 13 of 14, by filipetolhuizen
Glide 2.1.1 also works with the Voodoo2 using the variables above.
Reply 14 of 14, by Gamecollector
Glide 2.1.1 games:
Cybergladiators.
Mechwarriors 2: 31st Century Combat - OEM 3dfx version.
Outlaws (patch 1.1).
Pandemonium!
Pod (patch 2.100) (aka Pod 2.0).
Please try to test the others 4 games.
