First post, by DosFreak
- l33t++
http://forums.guru3d.com/showthread.php?t=368880
So in case you're new to SweetFX Shader Suite (or just SweetFX), it's a mod built on the InjectSMAA shader injector, that allows […]
So in case you're new to SweetFX Shader Suite (or just SweetFX), it's a mod built on the InjectSMAA shader injector, that allows you to apply a suite of post processing shader effects to your games.
You may have tried another shader injection mod before, like InjectFXAA, InjectSMAA or FXAAtool. SweetFX improves upon all of these.
You can add SMAA anti-aliasing , sharpening and tweak the color, gamma , exposure and more.
It's meant to allow you to improve the look of your games and change the look and mood of it to your liking.
If you use SMAA antialiasing instead of MSAA or an even more expensive antialaliasing technique you can also make the game run faster (than with MSAA)Effects included:
* SMAA Anti-aliasing : Anti-aliases the image using the SMAA technique - see http://www.iryoku.com/smaa/
* LumaSharpen : Sharpens the image, making details easier to see
* Bloom : Makes strong lights bleed their light into their surroundings
* HDR : Mimics an HDR tonemapped look
* Technicolor : Makes the image look like it was processed using a three-strip Technicolor process - see http://en.wikipedia.org/wiki/Technicolor
* Cineon DPX : Makes the image look like it was converted from film to Cineon DPX. Can be used to create a "sunny" look.
* Lift Gamma Gain : Adjust brightness and color of shadows, midtones and highlights (avoids clipping)
* Tonemap : Adjust gamma, exposure, saturation, bleach and defog. (may cause clipping)
* Vibrance : Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
* Curves : Contrast adjustments using S-curves.
* Sepia : Sepia tones the image - see http://en.wikipedia.org/wiki/Sepia_tone#Sepia_toning
* Vignette : Darkens the edges of the image to make it look more like it was shot with a camera lens. - see http://en.wikipedia.org/wiki/Vignetting )
* Dither : Applies dithering to simulate more colors than your monitor can display. This lessens banding artifacts - see http://en.wikipedia.org/wiki/Ditheri...age_processing )
* Splitscreen : Enables the before-and-after splitscreen comparison mode.It works with all 32bit DirectX 9 , 10 and 11 games (and many applications).
It does NOT work with 64bit game executables - use the 32bit version of your game if it gives you a choice between 32 and 64bit.
It works with all graphics cards as long as they support at least shader model 3.
It should work on Windows 2000 and newer, both 32bit and 64bit. So far tested working on WinXP , Vista and Win7. Windows 8 is untested - please report your findings (So far it seems to function if users edit their folder permissions first)
It may work on Linux using Wine - please report your findings.
