First post, by Soupdragon
What will the turbo button do on a typical 430tx chipset mainboard with this connector. Will it disable the cache or drop the bus down to 50mhz? The manual says feature reserved so I am guessing it might not work at all? Anyone have any experience of this main board it is a Gigabyte GA-586TX. I was thinking it could drop my 233mmx down to sub 486 speed with both the turbo off and both caches disabled if it worked.
Thanks
Reply 1 of 8, by badmojo
I've never seen a functional turbo header on a socket 7 board. Sometimes they include a 'green' header in the same position, but that just puts the whole kit and kaboodle to sleep I think.
Reply 2 of 8, by Soupdragon
Thanks bad. Don't think I'll risk buying it then.
Reply 3 of 8, by Filosofia
Yes, unfortunately every socket 7 mobo I've seen comes with the turbo "always on" and there is no way to shut it down, at least documentated 🙁
Reply 4 of 8, by stbunny
I've got GA-586ATV (i82430VX) with operational Turbo button that drops down external clock to 50MHz. Cache stays on.
Reply 5 of 8, by luckybob
I have a dual pentium pro that has a "turbo" option in the bios. labeled "deturbo". I wonder what they were smoking in engineering deparment. Why anyone would buy a $1000 chip and run it at 8mhz? BUT IT GETS BETTER! In the latest bios they changed the default setting to ON.
Reply 6 of 8, by stbunny
Why are we buy retro stuff for an insane price and wanna run it in half speed? )
If they were smoking smth it helped them to see the future where we need in "deturbo".
P.S.
Man, this gif is driving me crazy!
P55T2P4, Intel Pentium 133MHz, 32Mb EDO, S3 Virge 325, YMF-719s + SC-55, AHA-2940U2W, ST39175LW, UltraPlex40Max, Opti USB PCI, Sony CPD-G400P 19"
Reply 7 of 8, by elianda
Well usually Turbo switches between 66 and 50 MHz FSB on a socket 7 board.
(it would be worthwhile to try what it does, if the board is jumpered to 50 MHz FSB)
On some boards it seems to disable also the chipset caches. (thats NOT L2)
I really wonder what weird S7/SS7 boards you had. Every S7 board I have has working turbo functionality.
Youtube Channel
Reply 8 of 8, by badmojo
Maybe it's a regional thing, but I have ~ 10 Socket 7 boards in my shed ATM - all different - and none of them have a turbo header.
