First post, by Bladeforce
Hi may I ask if somebody would be kind enough to write a step by step on how to compile a dosbox with 3dfx support on linuxmint 13? I have spent hours reading and trying things off this forum but now my head is frazzled with all the different posts! How do I compile dosbox with patches? A simple step by step would be great!
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
if you have to ask, then it might be too difficult to begin with.
Maybe get some experience with compiling first, before tackling an advanced project.
If you do feel that you are experienced enough, then phrase your question better, like which patch should I use ?
Water flows down the stream
Reply 2 of 8, by Bladeforce
Hi, thats just it, I have installed glide using a tutorial on here and it is there but when i come to following a compile guide it goes all astray and the repsonses are just a jumble so if possible a straight tutorial would be great or even a precompiled binary that works on Linuxmint? Thanks for the reply 😀
Reply 3 of 8, by mr_bigmouth_502
Dumb idea, but maybe try installing nGlide in WINE and using the Windows version of DosBox with Guilkoza's patch. 🤣
Reply 4 of 8, by Davros
according to wiki theres a pre compiled binary
http://www.dosbox.com/wiki/SVN_Builds
look for ykhwong
Reply 5 of 8, by Bladeforce
Thanks for that. When I tried running that version i get an error "libSDL_sound-1.0.so.1: wrong ELF class: ELFCLASS64" and quits. Running the normal dosbox is fine obviously thoug hwithout glide support
Reply 6 of 8, by megatron-uk
It means that the libSDL_sound-1.0.so.1 library is for a 64bit kernel - I'm guessing yours is 32bit.
What does 'uname -a' show on your system?
https://www.target-earth.net
Reply 7 of 8, by Bladeforce
Hi, thanks it says
"Linux ade-LM13 3.2.0-32-generic #51-Ubuntu SMP Wed Sep 26 21:33:09 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux"
Reply 8 of 8, by Davros
Do you have to use linux ?
