First post, by rug
Hi.
I acquired a Gravis Phoenix stick, but I can't find the DOS drivers anywhere in the net.
Can someone help me with this? Maybe take some floppy images from yours and send them to me, please?
Cheers,
Rita Graça.
My DOS machine: MS-DOS 6.22, Pentium MMX 200MHz, 64MB RAM, AWE64 Gold, 4GB HD, Philips 19" CRT, 3"1/2 Floppy, CDROM, Parallel ZIP, ThrustMaster FLCS+TQL+Elite.
Reply 1 of 7, by sprcorreia
This is all i have for it. Please give it a try.
    Gravis Phoenix.7z
    716.63 KiB
    223 downloads
Reply 2 of 7, by rug
Obrigado! 😉
I'll give it a try.
Any chance for a User's Manual?
Cheers,
Rita Graça.
Reply 3 of 7, by sprcorreia
I don't have the manual, but i do have the old days FAQ. Hope it helps.
    Phoenix.txt
    26.27 KiB
    316 downloads
Reply 4 of 7, by rug
SPR you're a life saviour!
I actually installed the DOS software and configuring the joystick is quite straight forward. I though it would be something like the FLCS!
Unfortunately, I found out that the "soft" buttons are a bit non-functional, that is, I need to press them hard to make them work! 🙁
Apart from that, the joystick seems ok.
Cheers,
Rita Graça.
Reply 5 of 7, by rug
Any tips to revive the rubber buttons?
Cheers,
Rita Graça.
Reply 7 of 7, by rug
I sprayed some graphite on the contacts and that seemed to do the trick!
But only in the buttons on the joystick. The ones on the base, seem more troublesome, i.e., more screws to unscrew, possibility of tension springs jumping about, etc...
Cheers,
Rita Graça.
