First post, by 3246251196
Given that the contents of the store-bought duke3d CD is all written to a directory on my linux box named, for instance:
~/duke/cd
and that duke3d was successfully installed through DOSBOX into a directory on my linux box, for instance:
~/dosbox/games/duke3d
when I try to:
MOUNT D ~/duke3d/cd -t CDROMMOUNT C ~/dosbox/games/duke3d
and then:
C:SETUP.EXE{{Select Run DUKE3D option through SETUP program}}
I keep on getting the error:
Please put Duke Nukem 3D Atomic Edition CD in drive.
Also, in case anyone requests the CD-ROM INI file in the duke3d directory, it's contents is this: (and lowecase/upper is not the issue)
D:\support\
I have verified that such a directory exists and, within it, is the .IDF file.
