cooling fan wattage
First post, by ratfink
I'm wanting buy a front panel for fan control. Some allow up to 30w per channel, some only 20w.
I can't believe cooling fans take even 20w, but can anyone advise? I somehow doubt it will be stamped on the fans I have.
Reply 1 of 9, by Old Thrashbarg
Actually it is marked on the fans, albeit indirectly. (Assuming the labels haven't been peeled off.) Take the amperage and multiply it by the voltage, and you've got wattage.
Reply 2 of 9, by ratfink
I better have a closer look in thta case, thanks.
Reply 3 of 9, by TheMAN
sometimes, there are brand name labels applied over the original fan maker/spec sticker... you may want to see if that is the case
Reply 4 of 9, by luckybob
20W would be 1.67 A
30W would be 2.5 A
These would be INCREDIBLY loud and powerful fans. Even server grade 120mm fan don't crack 1.3 A
Reply 5 of 9, by Old Thrashbarg
Some of the fans they use in Dell Optiplexes are 2 or 2.5A. They're loud as hell when they ramp up to full speed, but also move a fair bit of air quietly at lower speeds. Of course they also draw less power at lower speeds, but when using such a fan with a speed controller, you'd still want to go by the maximum power rating just to be safe.
Reply 6 of 9, by ratfink
I'd be using the controller for my socket A dynatron fans. Only small fans but they run at 7000rpm. Deafening and no need for such high rpm.
Reply 7 of 9, by Joey_sw
is there any good fans 'benchmark' site out-there ?
Power usages,
Noise decibels,
Airflow volumes,
Cooling capability,
etc..., etc....
-fffuuu
Reply 8 of 9, by TheMAN
IMO, Sanyo Denki fans are the best
I haven't have one fail on me yet.... I still have ones working perfectly after buying them 10 years ago, run 24/7... they're far from quiet compared to today's fans, but I'm sure they now make quiet fluid bearing ones... in any case, they're industrial grade and used by many OEMs
Reply 9 of 9, by archsan
Joey_sw wrote:
is there any good fans 'benchmark' site out-there ? […]
Power usages,
Noise decibels,
Airflow volumes,
Cooling capability,
etc..., etc....
X-bitlabs have been doing the larger ones (120mm~140mm) over the years:
http://www.xbitlabs.com/articles/coolers/disp … -roundup-2.html
http://www.xbitlabs.com/articles/coolers/disp … -roundup-3.html
http://www.xbitlabs.com/articles/coolers/disp … -roundup-1.html
http://www.xbitlabs.com/articles/coolers/disp … an-roundup.html
http://www.xbitlabs.com/articles/coolers/disp … ns-roundup.html
