First post, by Yengoshi
I've been trying to get my Xbox 360 Controller working with DOS Box. I can get it so that fire works with the A button but it seems to get confused with the analog stick for movement. (I'll set the analog stick to move left = left in the games options, and it seems to move down or to the right instead.)
I then moved into the mapper on DOSBox (I had to install a new installation of Dosbox as I use D-Fend Reloaded to launch the games and the version that is included didn't seem to want to save the mapper changes. After changing the control options in the mapper, I assumed that if I set the games options to keyboard and used the same buttons I had changed to the controller in the mapper then it would use the controller but it doesn't.
I've also tried all the joystick types.
Anyone got any ideas? (sorry if the post is a bit confusing.)
Reply 3 of 15, by bloodbat
I have a DosBox build with specific Xbox-360 controller support (via TraxxAmigaEP's patch to use the POV hat), if you want to give it a try...though the controller works fine for me when using either the xbox 360 option or the default dosbox joystick option.
It also includes MT-32 emulation; Glide support, and Gulikoza's Direct3D patch, it is based off the latest (as of right now) SVN code.
It's optimized for SSE2.
You can download it here:
https://skydrive.live.com/redir?resid=96AD29F19839D999!390
Reply 5 of 15, by bloodbat
I use D-Fend Reloaded as a front-end and my controller options are never ignored, make sure you use a recent D-Fend Reloaded, though, just in case it's a bug in that program, if you're referring to mapper files, there's a an option in the "keyboard" section of D-Fend Reloaded to load a custom one.
Reply 6 of 15, by Yengoshi
How do you get D-Fend to see the one from the custom DosBox? As the custom one didn't create it and the only one I have is in a .map file which D-Fender doesnt see. Also do I disable the joystick on D-Fender?
Reply 7 of 15, by bloodbat
You need to create one using the DosBox internal editor (vanilla, custom, the one included with D-Fend, doesn't matter which).
Don't disable the joystick, I'd advise going through the included .conf file and reading the options; adding the option to D-Fend Reloaded's joystick section: "xbox360" (no quotes) OR using a .conf file with:
joysticktype=xbox360
Reply 8 of 15, by Yengoshi
bloodbat wrote:
You need to create one using the DosBox internal editor (vanilla, custom, the one included with D-Fend, doesn't matter which). D […]
How would I do this with D-Fender? (I'm a newbie.)
Reply 9 of 15, by yannara
In C:\Users\user\AppData\Local\DOSBox\dosbox-0.74.conf I set joysticktype=xbox360 but no help. We are trying to get Mortal Kombat 2 and Trilogy to work with Xbox, but no chance. The setup does not feel any keys from controller pressed.
Fan of Doom, Mortal Kombat, Duke, Blood
Reply 10 of 15, by bloodbat
File -> Program Options
Profile Editor -> Default Values
Category: (DosBox) Joystick
and add a line that reads xbox360
After clicking "Ok" it should be available to select in the profile editor.
Ok, first and foremost that's vanilla DosBox's .conf file and xbox360 is not a valid joystick type, the build I offered for download includes its own dosbox.conf you can edit in the folder produced when uncompressed, if looking for the .conf file in \appdata\local\dosbox the file name for my build (in case I forgot to add a default .conf or you deleted it) is "dosbox-SVN 3802.conf" minus the quotes.
MK II and Trilogy supported Gravis Gamepad, that is it will only detect 4 buttons, so, for a more complete experience I recommend using an app such as joytokey to map joystick input to keyboard and get all the buttons working as they should.
I've never had any problems using any DosBox version with my 360 controller when it comes to button detection, so, first I'd check if Windows is detecting the controller and install microsoft's drivers for it if I haven't done so, what's the output of the status window? Mine (using official, stable and vanilla DosBox) reads like the attached image.
    32.92 KiB
Reply 11 of 15, by Yengoshi
bloodbat wrote:
File -> Program Options […]
Ok my custom xboxcontoller now shows in D-Fender under joystick options. The game still isnt working with it. And D-Fender isnt seeing the custom map file from DOSBox?
Reply 12 of 15, by yannara
I came back for this just now, after 6 months 😁 but could you release the file again I could download? So your config adds a support for xbox controller?
Reply 14 of 15, by mr_bigmouth_502
I've been using the unofficial XBCD 0.2.7 drivers with a wired 360 controller to play OMF 2097 under DosBox 0.74, and it works pretty well. 😁 I can now pull off all sorts of crazy moves that I struggled with just using a keyboard.
It was somewhat difficult to get the unofficial drivers working because I had to dig into my system files to remove remnants of the official Microsoft drivers (along with another unofficial driver I tried that didn't work), but once I got that taken care of and installed the XBCD drivers, they worked perfectly. 😁 I didn't even need to change anything in DosBox's configuration.
Reply 15 of 15, by bloodbat
There's an alternative 😀
What I do use is the DInput force feedback wrapper (probably has some fancy name, but I don't read japanese 😖)
