Glidos and STEAM Tomb Raider 1
General information and assistance with GliDOS.
Postby Pal » 2012-11-30 @ 00:21
I could not get Glidos to work with the STEAM release of Tomb Raider. Has anyone got this to work yet? Or will support be added?
http://store.steampowered.com/news/9461/
Thanks
Pal
Re: Glidos and STEAM Tomb Raider 1
Postby Glidos » 2012-12-04 @ 10:36
It should be possible. I'll get a copy myself and have a go when I get a moment.
Until then, if you could post a list of the files that are installed and their sizes, I may be able to tell you how to do it.
User avatar
Glidos
Postby Explorer » 2013-1-04 @ 22:03
Hi
Today I tried the Steam version of TR1 with Glidos 1.51 using the same installation method as the GOG version and it works.
Unfortunately although the ambient or background sounds and the title theme music can be heard, the other game music from the audio pack does not seem to work.
Is there anyway to get the music to work ?
The Steam version uses DosBox 0.74
Thanks
Explorer
Postby Glidos » 2013-1-05 @ 07:59
Yes, I've heard of this problem before. I'll give it a try myself and see if I can find the cause.
In the mean time, there is something you can try that should fix it. Download and install the archive here. Then change the Glidos config to use that tomb.exe, but leave the iso path unchanged.
User avatar
Glidos
Postby Explorer » 2013-1-05 @ 12:41
Thanks, the audio pack is now working ! :)
Hope your able to find out what causes this problem in the first place
Explorer
Return to GliDOS General
Who is online
Users browsing this forum: knowledge [bot] and 0 guests
