First post, by RMcJimsey
I'm attempting to get an old DOS accounting program Accpac Plus to run but am recieving the above error. Does DosBox support the "SHARE" command?
Water flows down the stream
VERY HELPFULL!! Thanks, instead of being arrogant perhaps you could point me to a usefull emulator or just answer the question as "No". I came across DosBox and found it compelling! I certainly didn't mean to step on any "Gamers.." toes! I apologize and will delete it along with my account. Thanks again... 😒
Who told you DOSBox was an easy virtual machine for everything under the sun?
Because that ain't true.
IT incompetence about the above (i.e. taking shortcuts to not install vmware/vpc/virtualbox etc to run database software, just for dodging vital steps like installing proper copies of MS-DOS, setting up the NICs, etc) to run non-games has been a bane of the dosbox forums for the past few years.
long live PCem
Debian's fucked
