First post, by Kahenraz
- Oldbie
Both CTCM and CTCU use a very mundane check to guess whether it's running in windows. It looks for the environment variable "winbootdir". How clever.. 😒
This creates problems for those who are actually running in pure DOS but also have a Windows installation with this variable set.
Here is a patched set of CTCM and CTCU that removes this check.
The advantage of this patch is that it allows CTCU to be used for graphically modifying your PNP Creative sound card. CTCM also will sometimes fail to load as well depending on some configurations when it thinks there is a discrepancy between the DOS and Windows resources. I believe this corrects that as well.
