First post, by VictorB
I'am building a Retro 3dfx gaming machine era 1999/2000. The parts i choose will be the ultimate gaming machine which i couldn't afford back in these days. So everything is going to be top of the line 😁
So first my introduction video of the project where i show the hardware. And give more details over my system back in those days in the description.
http://www.youtube.com/watch?v=5PAIUJCJHGM
Testbuild! It's much safer to test the hardware in a case then on my desk. For so far the setup is stable and with windows 2000 no errors.
But the build isn't cool without a great case! So my choice is the Aopen HQ45!! The most known ugly case ever! No cooling option allmost no hd bays.
Lets mod it!!
It will be a total rebuild 😁
I made this new HD rack. Its looks awesome and fill up the space in the front. There will be a big sidewindows to show all the epic expension cards
Custom front made of a top cover of a chieftec tower
Another youtube video where i show the start of the casemod! 😀
http://www.youtube.com/watch?v=tc_VzN_mVnA
Lots of metal works for the new custom front.
The front fans installed
Testfit 😁
The config for now 😁 (it will change but this is what i had in my mind for ths build)
Pentium3 500
Asus p3b-f
512mb pc133
20gb seagate
Matrox g400max
2x Voodoo2 Sli
3com 3c905b
Awe64 Gold isa
The OS is windows 2000 and i have Quake2 running (also played out the single player on this setup 😁 ) And offcourse Halflife1 The most Epic game ever!!
Reply 1 of 119, by Tetrium
My god!
What a lot of work man!
And what a load of cooling in there!
I used to have 3 such cases. Tried to give em away for free...there were no takers 🤣
Edit:And welcome to Vogons!
My retro rigs (old topic)
Report spammers here!
Reply 2 of 119, by VictorB
Thanx 😁
I only bought the Voodoo2 cards with cables for 25 euro and the motherboard cpu mem for 10 euro. The rest was for free 😁 I only paid shipping for the Matrox g400max and 3com card. So its a pretty cheap build! Even the AWE64 Gold was for free 😜
Yeah the Aopen case is so ugly that no one wants it haha.
Is there a better way to integrate the youtube clips on the forum?
Reply 3 of 119, by Tetrium
Not that I know of, sry.
I just dump the full link when I want to link to youtube 😊
Reply 4 of 119, by chinny22
Slot 1 and V2 SLI my favourite things!
I liked how you replaced the 1 fan and useless com port holes with 2 fans, I may have to “borrow” that idea from you.
I watched your 1st video, think I would keep things simple and stay with IDE, although as you’re going to be running Win2k and not Win98 like most maybe there is a performance gain to be had?
It’s a nice setup, not much different to how mine (hardware wise) stated out but had to get a 1GHz CPU and with that much power the TNT Pro gave way to a Gforce ti4600 goodbye period piece hello speed king-ish
Reply 5 of 119, by nforce4max
You might want to reconsider improving that drive rack as the angle that the drives are mounted creates uneven wear on the drive spindles that will result in shorter life.
Reply 6 of 119, by VictorB
Yeah slot1 is Epic 😁
chinny22 you can use any idea what you like! But you must show it hahaha 😀 The raid plan is just because it can 😀 if i want real speed i game on my I7 with gtx570 😁. I choose the era 1999/2000 so i can have limited choice in my setup 😜 So no 2003 agp card for me 😀
The drives never wil be used for 24/7 and they all have fluid bearings so i think there won't be a problem. And someone is collecting more 40/80gb ide disks for me so i get enough spares 😀
Because the video links are a bit hidden between the pictures here the links!
Another youtube video where i show the start of the casemod! 😁
Reply 7 of 119, by nforce4max
I hate to see such drives go to waste that way as they are about the fastest ide drives that one can buy, I learned the hard way with one of those seagate drives and those low profile Maxtor drives that you have it is something you don't want to do. It doesn't matter much the bearing type. During the 80s and 90s they used to balance the entire spindle stack by using a screw that attacked to the cover but since the early 2000s they stopped. When the drive isn't setting flat with the label side up and at any odd angle or vertical the load on the spindle isn't evenly loaded. It causes uneven wear on the bearings and causes them to prematurely fail over a much shorter time than would be the norm and will slow the spindle over time so performance degrades as well.
I got the drives and the experience the hard way so just drill some extra holes then you won't have to bother replacing any for years if they are still in great shape.
Reply 8 of 119, by VictorB
nforce4max Maybe your right. it doesn't feel good to use the maxtors in this way. I getting more old harddrive so maybe i can test 1 (Not the fast maxtors) if it goes well.
Nice i found and installed SIN 😁 Quake2 based shooter 😀
Reply 9 of 119, by cdoublejj
windows 98se with mods is another good choice. would you benefit from a faster pentium 3?
Reply 10 of 119, by VictorB
Offcourse you wil benefit from faster P3 also from a faster videocard but i choose the 1999/2000 era and i will stick to that. I have also a pentium3 450 so if the case is finisht i gonna overclock and see which is the best cpu 😁
I never been a fan of windows 98se. Which mods do you use?
Reply 11 of 119, by Tetrium
Theres the unofficial Service Packs, those are the only mods I know for 98SE
Reply 12 of 119, by cdoublejj
I also use Kernel Ex as well as unofficial Service packs i also use a Microsoft wifi card with MS wifi software but, it only works with WEP.
Any reason you guys didn't get faster CPUs?
Reply 13 of 119, by sebaz_ri
Just for curiosity, which game you are playing in the pic with the white and black floor
Reply 14 of 119, by keropi
that's Half Life, a fitting game for this build 🤣
Reply 15 of 119, by VictorB
Yes its halflife1 1 one the best games! Iam now playing SIN (quake2 based shooter) i plays nice and its fun. The game i played before this game was farcry3 haha
I get today some HD's 8.4 13 40 60 2x80 gb ide 😁 i will make a picture and i gonna test them this week 😀
Reply 16 of 119, by cdoublejj
you might also check out this voodoo sli thread.
Reply 17 of 119, by m1919
Heh, Half-Life and SIN were some of the first games I installed on my retro Xeon rig. 😁
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
Reply 18 of 119, by VictorB
Yeah Halflife is great i played it so much! The first game i installed and played the whole single player was Quake2 😁
Last week i found SIN 😁 I played it back in 1998 on my Pentium1 with voodoo2. So i gonna play the whole single player also 😁 And i gonna install old need for speed games 😀
Reply 19 of 119, by m1919
Yeah, I played that game a lot on my P233 back in the day.
