First post, by Glitchologteam
hello there, I have not much to say other than the game simply do not run. I get either a black screen or the computer state that it is already running when its not the case
This entry in the PGA Tour Golf serie do not seems to be well known.
http://www.mobygames.com/game/pga-tour-gold (here some info on it)
Ive tried to test on my windows 7 ultimate 64 bits, vmware windows xp, 98 , 95 and a physical windows 2000 computer but unfortunatly it do the same thing on each system
Reply 1 of 1, by Jorpho
If you check Task Manager when you get that message, can you see if the process is still running?
Are you using the same monitor whenever you try to run the game? (That shouldn't affect VMware, though.)
And are you using original disks, or is this a copy you downloaded from somewhere?
