First post, by subhuman@xgtx
Vogoneers.. once again I need you help 😵 :
You know I bought a Chaintech dual socket 462 Motheboard many months ago but the thing refuses to give me video from the AGP slot 😵; the award bios just gives the common three beeps, complaining about video and nothing else.
However, it's quite strange how can I put a normal PCI vid card along with other AGP boards and actually see some info of the card connected to the agp slot by using a DOS pci sniffer. I also noticed that this board has a 6pin aux connector besides the normal 20 + 4 ones that all Dual 462 boards have..
Perhaps, am I forced to get a PSU which has that connector in order to have video from the slot? or is it "fux0r3d"? zfter all? 😢 . Even worse is the fact that since this is a quite unknown mobo, I can't seem to be able to find even a single pdf manual of it on the net. : 🙁... If I were able get this board totally working it would be so great.. so I could start with my Dual MP 2800 + AAlchemy 8164 Project 😎
Thanks everyone!
Reply 1 of 9, by subhuman@xgtx
up 🙁
Bear in mind I usually post to the forums using my old systems.
Reply 2 of 9, by luckybob
its not uncommon for motherboards with agp pro to require the aux power to be connected prior to booting. My dual slot 1 from intel (or840) is such a board.
it will not post with ANY agp video card? what bios version do you have? I found 1008 laying around: http://download.driverguide.com/driver/BIOS+7 … ch/d157595.html
Reply 3 of 9, by subhuman@xgtx
Ahhh. 😜 I have the latest bios(the one which adds Barton 2800MP support) and no, it won't post with any agp card, no matter if it's 2x or 4x; but as I said, I can read some info of the card plugged in that agp slot by booting up with a pci card and running a PCI sniffer
Reply 4 of 9, by luckybob
give this a shot: http://www.ebay.com/itm/290838358531
Reply 5 of 9, by subhuman@xgtx
luckybob wrote:
dang, seller doesn't ship to south america :'(
Reply 6 of 9, by eshwayri
I know this is an old post, but just in case someone with this motherboard finds this, I have the manual for this motherboard along with the drivers I used back when I ran mine.
Reply 7 of 9, by cskamacska
eshwayri wrote on 2021-12-04, 19:42:
Thats great! Could you share it with us?
There are 0711 (07/11/2002-AMD762-IT8712-DD6S7C0CC-00), 0715, and 1008 (10/08/2003-AMD762-IT8712-DD6S7C0CC-00) BIOS versions on MOBOKIVE
https://www.elhvb.com/MOBOKIVE/ARCHIVE/Chaint … 7kdd/index.html
but no manual to be found. 🙁
the loyal slave learns to love the lash
Reply 8 of 9, by PcBytes
Of note, I remember user Cuttoon buying a MSI K7T266 Pro-R and wondering what was that 4 pin for.
Apparently it is standard 12v P4 plug from what it looks (at least I think the pinout is exactly the same as a standard 12v P4 plug), but instead of feeding the CPUs, it's used for the GPU.
Reply 9 of 9, by cskamacska
PcBytes wrote on 2022-06-18, 15:38:
Apparently it is standard 12v P4 plug ... but instead of feeding the CPUs, it's used for the GPU.
You are probably right as the motherboard features a universal AGP Pro slot, and that theoretically could eat up 9.2 (4.17?) Amperes on the 12V rail.
The processors have a nice and deprecated 6 pin AUX connector for themselves.
