First post, by Stojke
- l33t
What is a realistic price for this card? Its in good shape and has 2x 16MB FPM RAMs.
And its boxed with all content.
[EDIT]
Not mine btw, i want to buy it from one guy.
[EDIT]
I sold one recently for 80 euros plus postage. Boxed, with every bit included, but no RAM.
Mine was the Turtle Beach Pinnacle Project Studio with the Homac MIDI daughterboard.
If it is in good working condition, and comes with the daughterboard, it was real cheap.
It's the regular version... No Homac daughterboard, no digital i/o, etc..
You can still use the onboard MIDI synth and it's very nice.
Heres how the Project Studio looks like:
Its here.
It has an Crystal CS8425-CL on that little addon card, but no larger daughterboard.
It does sadly have minor damage. The AUX IN has been damaged, it seems that some one accidentally pulled the cable out and broke the little plastic on the side. Still need to test is it only the plastic or are electronics also damaged.
And yeah, it has 2x 16MB Modules, Floppy and a CD.
When installing drivers the setup asks me for a serial?
NVM, it works 😀
I'm about to buy the project studio as well, apparently it also includes a VHS 🤣 when every ca 1997 PC can handle an AVI or MPEG files oh well. I understand the soundcard is 0 compatible with games.
Trailing edge computing.
wrote:I understand the soundcard is 0 compatible with games.
Guessing that you are refering to DOS i have to say that it's not true.
In DOS the EIDE port and joystick port will both work. And you can even use the on-board Kurzweil Synthesizer as a General MIDI device for DOS games.
And by personal experience i can say that the synth is very good.
Various posts on here say it's probably not compatible with dos, so some first hand experience rather then even educated guesswork is good to hear.
One particular post says it's not sb or adlib compatible - any verification on that aspect?
wrote:One particular post says it's not sb or adlib compatible - any verification on that aspect?
The card is incompatible with any kind of Sound Blaster or Adlib. But you can add one to the system and enjoy both cards.
Pretty much what we do with the SW60XG or SCC-1.
I know the sound effects (digital sounds) won't play in this card under DOS, it has a completely different achitecture, Hurricane memory based, instead of IRQ + port + DMA, so unless an emulation software layer exists which I doubt possibly only the Synth part has a chance.
I used to have a Monterey (Tahiti + Rio daughter board) and I remember I wasn't able to make it work with X-Wing
wrote:I used to have a Monterey (Tahiti + Rio daughter board) and I remember I wasn't able to make it work with X-Wing
The MultiSound Monterey had only one requirement printed in the box:
(This is taken from my own MultiSound Monterey box)
wrote:wrote:I used to have a Monterey (Tahiti + Rio daughter board) and I remember I wasn't able to make it work with X-Wing
Do you still have the card on its box ? omg!! I only have left a couple of manuals and a few ZIP memory, gave away the Monterey to a friend who lost it, what other TB hardware do you have? any pictures or threads with your stuff ?
wrote:Do you still have the card on its box ? omg!! I only have left a couple of manuals and a few ZIP memory, gave away the Monterey to a friend who lost it, what other TB hardware do you have? any pictures or threads with your stuff ?
I think this is the best answer:
I've been downsizing my collection, but i still have a few TB cards.
The Pinnacle Project Studio, Monterey, Tahiti, Maui and Santa Cruz.
I have no threads for my cards.
Wow!! what other cards did you own?
I have to take a few pictures of the stuff I've got
wrote:Wow!! what other cards did you own?
There were others, mostly low end like Monte Carlo. And there is the fact that i had more than one unit of some models. I think i still have 2 Maui.
If you are refering to another brands, i think i may have more than 50 different sound cards and a few Wavetable Daughterboards (Creative, Yamaha, Roland, Terratec, ESS, Guillemot, Mediavision, Gravis, Aztech, etc.).
