First post, by leileilol
Is there any tool or any sort to tweak the composite output? It's hard trying to get sharp 720x480 output from a Rage128 like I was able to accomplish with the Voodoo3 3000.
Another problem is that it defaults to a fuzzy blurry 'ice' signal for any other resolution than the desktop's, and on restart
Reply 1 of 3, by Logistics
Make sure to use a very high quality composite cable. Preferably, from a manufacturer who guarantees a 75-ohm impedance. I hooked up someones TV flone time, and they had a thick, high-quality composite cable that made for a better picture than my cheap component cables. This is going to be very important if your card has weak signal.
Reply 2 of 3, by leileilol
I doubt it has to do with having a weak signal. I've used the same cable to produce this sharp video.
Reply 3 of 3, by Logistics
Well, it can never hurt to have a great composite cable. Was that video at the same resolution you're trying to produce, now?
