First post, by ratfink
I put together this machine to play with DOS and WFWG3.11:
GA5AX
IDT Winchip C6 200mhz
Ensoniq Soundscape Elite
SB Pro 1
Voodoo Rush
No great logic to it except I wanted mainly something for older DOS titles and was planning to use it with caches disabled to act like a 386. The voodoo rush was to replace a dying S3 [other thread] but it means with cache fiddling maybe it can run early glide games.
Anyhow, just for simple testing of the SB Pro I use vinyl goddess. Of course that needs a fast 486 so I enable the cpu caches. Music on the main menu is fine [FM synth]. Music on the enter-a-level screens is massively too fast, but slows when I press a key...
The game usually plays fine with a 486, socket 7 or upwards, in fact it normally plays fine on this motherboard with an sb16 or ews64. Or an sb pro 2 for that matter. But not this sb pro1.
So...this sound card is sensitive to the cpu speed?
Or could it be something else?
