First post, by hifidelitygaming
Although I toyed briefly with GLIDE wrappers awhile back and found them eye-openingly impressive, I haven't touched them in years being too busy to game. Near as I could tell they did EVERYTHING that the real Voodoo cards did, just potentially much better - forcing higher resolutions, 32bit color, possibly other things.
Or did they? Could someone with better familiarity than me comment on that? I remember hearing of the "22bit color" of the 3dfx cards which offered smoother graphics, at the expense of sharpness. I wonder whether this feature (or bug depending who you talked to) has ever been emulated for instance. Or whether there are any other special abilities which would give a person a want to have a real 3dfx card for anything except nostalgia.
I ask because my 5500 seems to have had the RAM die at some point, discovered when I pulled it out of storage. 🙁
Can one build an ultimate GLIDE gaming rig, playing everything that ever was playable in GLIDE without compromise, or even better than it originally could play (on even a voodoo 5 6000) using the wrappers? Including the DOS only games? The only games I ever tried with a wrapper were Need for Speed 2se and 3 but seeing them in 1600x1200 with the fading raindrops on the windshield as far as I could tell looked perfect at the time.
