First post, by Apollo2
hey. I have a problem with this game.
images from the game:
http://img46.imageshack.us/img46/7872/15223745.jpg
http://img248.imageshack.us/img248/3028/52648449.jpg
http://img694.imageshack.us/img694/5228/92042549.jpg
http://img839.imageshack.us/img839/9177/77613417.jpg
When I play this game with DOSBox, the game sometimes stuck. The image of the game freezes, and need to run the game again to continue playing it.
When I start the game without DOSBox, and compatibility of the file I'm doing: "Run this program in compatibility mode for windows 95" - The game runs properly and not stuck ever. Only DOSBox, the game stuck sometimes.
There is a solution for the running game with DOSBox? Or have the option to run the game in windowed mode? Thanks in advance.
Reply 1 of 3, by rcblanke
Maybe try limiting the max. amount of cycles, for example using
cycles=auto limit 80000
Reply 2 of 3, by Apollo2
Edit: I think it solved the problem. I'm not sure .. so if it still continues to stuck, I'll update.
Reply 3 of 3, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
