First post, by northernosprey02
I have question about CPU upgrade for top-tier OEM PC (like Dell, HP, etc).
It is possible to upgrade to latest CPU (like AMD K6 on Socket 7 system and Pentium III Tualatin on S370 system) on OEM PC?
Sorry for my bad English
Reply 1 of 2, by PcBytes
If the case allows it,you can even shove a Athlon system in it with some proper cooling (if the PSU is not aligned it the vertical position rather the normal layout you're okay)(micro ATX only!)
Reply 2 of 2, by Tetrium
That really depends on the board. Often OEM motherboards will have even artificial CPU limitations making an upgrade nearly impossible.
My retro rigs (old topic)
Report spammers here!
