First post, by exofreeze
- Member
If I turn the soundblaster off in the conf file, Lomax Boulders loads fine. However I have tried sbpro, sb16, and sbpro2 - all of which cause the game to lock on start-up.
Interestingly, there is a soundset utility that detects the card just fine and then proceeds to play sound effects. There is also an option to choose your own settings instead of using the init settings. However upon launching the game, it seems to ignore this and simply try to re-init the card, at which point it locks up dosbox and I have to force close the whole process.
Out of curiosity I tried the SVN build and the program wouldn't even launch there, it simply gives runtime error 002 at 06c0:09d0
The game is shareware and can be found quite easily on the web.
