First post, by tayyare
The description sounds like totally bogus. Anyone see something like that before?
http://www.sahibinden.com/ilan/alisveris-bilg … -70570371/detay
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 1 of 7, by Tetrium
I can't read the description as it is in a foreign language, but it looks like some kind of adapter to me.
My retro rigs (old topic)
Report spammers here!
Reply 2 of 7, by tayyare
It's in Turkish, but the problem is, description does not make sense to me at all, although turkish is my native language.
It has a 50 pin external SCSI connector, and an internal 40 pin IDE connector, and a 5 pin something...I understand it is a adapter of sorts, but what it is exactly, that is what I really wonder...
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 4 of 7, by NitroX infinity
I think it's an adapter to either hook up an IDE drive to a SCSI cable or the other way around.
Edit; reading the description again. It could be a SCSI to USB adapter; you hook up the small cable to the USB header on your motherboard and hook up a SCSI cable/drive to the connector.
Reply 5 of 7, by Great Hierophant
This is a very curious device. First of all, the external connector has 100 pins. No ordinary SCSI device uses a 100-pin connector. It also has a 40-pin connector typically used by IDE drives. It seemed designed in part to bring a USB port from a motherboard to the edge of a case. It uses a weird 6-pin USB header cable.
I think it may be an internal to external IDE adapter for some proprietary device with the USB connector being used to power the external device. Unless there is some kind of circuitry on the underside of the board, I am running with that.
Reply 6 of 7, by Jepael
My guess is it is some kind of board for IDE hard drive dock, like those used get a swappable 3.5" hard drive into 5.25" front panel slot. But what confuses me that there is no standard floppy or HDD power connector to feed power.
Perhaps this is a back panel bracket instead for a box with external IDE drive?
If it only takes power from USB, it could be for 2.5" laptop IDE drives, as 12V is missing. Or then the external box requires a separate power supply.
Most likely not very interesting anyway, looks like a completely passive adapter.
Reply 7 of 7, by tayyare
Thanks a lot for the input. I have unfortuntelly a stupid interest in anything SCSI, so I just wondered what it was.
The seller claims that it is either a IDE/SCSI adapter (I've seen real ones and rememebr they were real curciut boards with real chipsets) or a USB/SCSI adapter (WTF?..). Both sounds like BS, and I see you guys also think the same.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
