First post, by Glitchologteam
Hi there again, sorry for creating two thread. This game ive got in the same bunch as Thunderblade also has its share of problem, however, unlike Thunder Blade with its protection problem, this game has technical problem.
Installation work well and install correctly
- Sound test shows that sound effect and voice works
- Sound test also show that music works
Now in the game (Its the first time I play this one)
- In the beginning of the game, you start in a room with 2 men. If you try to speak to those two, you will get a closer view of them and it look like they are talking, but I don't heard any voice or text showing up. Also, only the music seems to play. I walked over some room until I went to the hangar to start the first mission. When I go in the plane, I get a screen that say ''LOADING MISSION''. Unfortunatly, it seems that the game freeze right there, because it has been more than 10 minutes since ive let the game open.
Despite the fact that it is ''supported'' in the compatibility list, some comments say the same as me (Music only and Freeze at the loading screen). Is there something I can do about it?
DOSBOX 0.74 Default Option
Using cd image comming from the CD I bought
Windows 7 Ultimate 64 bits
Its the first time I get that many game that do not work with DOSBOX at first.
Thanks in Advance
