First post, by Robin4
I found this link with google:
http://abit.ws/file.abit.com.tw/pub/download/bios/
Its still possible to download abits bios files.
Reply 1 of 7, by sprcorreia
Did you try any download? Better check again.
Reply 2 of 7, by RogueTrip2012
Downloaded ok for me on Firefox. ".exe" for bios is scary and would go over with virus scanner.
I grabbed the 18+GB compressed file from somone on the forums. Re-compressed to 16.8 using 7-zip.
EDIT: the file I got used ".exe"s also. I'd still check the file just in case.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>WXP/W8.1 . AMD 960T . 8GB . GTX285 . SB X-Fi . 128GB SSD
> Win XI . i7 12700k . 32GB . GTX1070TI . 512GB NVME
Reply 4 of 7, by Robin4
Yes i have tried one file, to see if it was working..
Then i posted this topic.
I cant give your garantee if everthing should work.. But its better then nothing actually.
Reply 5 of 7, by Old Thrashbarg
Do you mean the file worked (as in, it was the proper size and you successfully flashed a BIOS with it), or do you just mean that the download worked?
I tried to wget a full copy of the archive, and aside from the .txt description files, there was not a single good file in the lot... all the .zip and .exe files are the same <1kbyte files that keropi found. So from what I'm seeing, it's really not better than nothing.
Reply 6 of 7, by sprcorreia
Yeah, that's exactly what happens. It just downloads a dummy file...
Reply 7 of 7, by keropi
actually the 16bytes you get for .zip and .exe files are the first 16bytes of the file...
so it's not completely broken, you get treated with 16bytes of the file you need 🤣 🤣 🤣 🤣 🤣 🤣
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
