First post, by TheLazy1
Is anyone else trying this?
It's certainly an odd way to spend time, but eh...
/proc/cpuinfo
processor : 0vendor_id : AuthenticAMDcpu family : 4model : 14model name : Am5x86-WTstepping : 4fdiv_bug : nohlt_bug : nof00f_bug : nocoma_bug : nofpu : yesfpu_exception : yescpuid level : 1wp : yesflags : fpubogomips : 61.05clflush size : 32cache_alignment : 32address sizes : 32 bits physical, 32 bits virtualpower management:
/proc/meminfo
MemTotal: 36976 kBMemFree: 27276 kBBuffers: 0 kBCached: 6844 kBSwapCached: 0 kBActive: 4224 kBInactive: 3372 kBActive(anon): 780 kBInactive(anon): 12 kBActive(file): 3444 kBInactive(file): 3360 kBUnevictable: 0 kBMlocked: 0 kBHighTotal: 0 kBHighFree: 0 kBLowTotal: 36976 kBLowFree: 27276 kBSwapTotal: 0 kBSwapFree: 0 kBDirty: 0 kBWriteback: 0 kBAnonPages: 768 kBMapped: 1152 kBShmem: 40 kBSlab: 1544 kBSReclaimable: 456 kBSUnreclaim: 1088 kBKernelStack: 224 kBPageTables: 128 kBNFS_Unstable: 0 kBBounce: 0 kBWritebackTmp: 0 kBCommitLimit: 18488 kBCommitted_AS: 1576 kBVmallocTotal: 991224 kBVmallocUsed: 20 kBVmallocChunk: 991204 kBHugePages_Total: 0HugePages_Free: 0HugePages_Rsvd: 0HugePages_Surp: 0Hugepagesize: 4096 kBDirectMap4k: 40960 kBDirectMap4M: 0 kB
lspci -vvk
00:0d.0 Mass storage controller: Promise Technology, Inc. 20269 (rev 02) (prog-if 85)Subsystem: Promise Technology, Inc. Ultra133TX2Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=slow >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-Latency: 64 (1000ns min, 4500ns max), Cache Line Size: 16 bytesInterrupt: pin A routed to IRQ 11Region 0: I/O ports at fff0 [size=8]Region 1: I/O ports at ffe4 [size=4]Region 2: I/O ports at ffa8 [size=8]Region 3: I/O ports at ffe0 [size=4]Region 4: I/O ports at ff90 [size=16]Region 5: Memory at ffbe8000 (32-bit, non-prefetchable) [size=16K]Expansion ROM at ffbe4000 [disabled] [size=16K]Capabilities: [60] Power Management version 1Flags: PMEClk- DSI+ D1+ D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-Kernel driver in use: pata_pdc2027x00:0e.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA 2164W [Millennium II] (prog-if 00 [VGA controller])Subsystem: Matrox Electronics Systems Ltd. Device 2007Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop+ ParErr- Stepping- SERR- FastB2B- DisINTx-Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-Latency: 64Interrupt: pin A routed to IRQ 12Region 0: Memory at fe000000 (32-bit, prefetchable) [size=16M]Region 1: Memory at ffbec000 (32-bit, non-prefetchable) [size=16K]Region 2: Memory at ff000000 (32-bit, non-prefetchable) [size=8M]Expansion ROM at ffbd0000 [disabled] [size=64K]00:10.0 Host bridge: United Microelectronics [UMC] UM8881F (rev 04)Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-Latency: 000:12.0 ISA bridge: United Microelectronics [UMC] UM8886A (rev 0e)Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-Latency: 000:12.1 IDE interface: United Microelectronics [UMC] UM8886BF (rev 10) (prog-if 8a [Master SecP PriP])Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-Region 0: I/O ports at 01f0 [disabled] [size=8]Region 1: I/O ports at 03f4 [disabled]Region 2: I/O ports at 0170 [disabled] [size=8]Region 3: I/O ports at 0374 [disabled]Region 4: I/O ports at 1000 [disabled] [size=16]
It's running kernel 2.6.32 and a uClibc based userspace.
Bootup takes 2 or so minutes, but keep in mind this system has no L2 cache.
So far the only issue is that I cannot get the matrox framebuffer to work, it just can't probe the card for some reason.
