Pc frogger game 1997 version
First post, by gow75
😕 how can i get Frogger pc version to run in dosbox. I have the CD and want to play it. I am running Windows 7 pro version with latest dos box installed. do i copy the contents of the cd to a folder then run. will it run in dosbox?
Reply 1 of 27, by leileilol
You don't. It is a Win32 game.
You can run it in Windows 7. You can even play it with nGlide at 1920x1080. There will be no music but it'll still be playable.
Reply 2 of 27, by gow75
thank you but i have installed it on windows 7 and it crashes i get the send to MS Prompt, send or dont send. thats it. i do use a cd crack of course because i dont want to keep the cd in it.
Reply 3 of 27, by Davros
ms prompt ???
"do i copy the contents of the cd to a folder then run"
No you absolutely dont do that you run autorun or setup.exe or install.exe
Reply 4 of 27, by gow75
ok im more confused now i got one person saying i cant use Dos box but that i can use MSDOS. another that i can install it and it works on windows 7 which is it. please provide breakdown how i should approach this. thanks
Reply 5 of 27, by Jorpho
No. No one is saying that. Don't do that.
Reply 6 of 27, by gow75
ok so how do i do it... if it is a 32bit game it should work on Windows 7 pro. I have a 64bit processor I3. i love your And gate picture...
Reply 7 of 27, by Kurasiu
I played Frogger 3D not that long ago, on a Windows 7, 64-bit version, even without nGlide, it should work perfectly normal for you. And regarding music - weren't those CD-DA tracks?
Reply 8 of 27, by Davros
who told you you can use msdos ?
i was asking what the hell is a ms prompt ?
have you installed the game ?
install to c:\games\frogger (dont install in program files or program files(x86)
is your windows version 64bit ?
is the frogger installer 16bit or 32bit ?
Reply 9 of 27, by leileilol
The Frogger installer is 32-bit. The Frogger game is 32-bit and uses DirectX. I've also played the game in 64-bit Windows 7.
Reply 10 of 27, by gow75
MS prompt umm dos prompt same diference. yes i installed it on my windows 7 pro 64bit pc. how do i determine if the installer is 16 or 32 bit. the game is Frogger (1997) on pc made for Windows 98/95
Reply 11 of 27, by Davros
so you saying when you run frogger you see this ????
that is the nearest thing win7 has to a msdos prompt............
ps: if the installer worked dont worry about it
what folder did you install to ?
Reply 12 of 27, by gow75
no i do not see that. I run the frogger.exe from the disk and run thru the wizard and installs fine but when i launch it doesnt work. just get the MS crash report sorry didnt know you meant that. says to send or dont send annoying popup. my specs are Windows 7 pro 64bit, I3 processor, biostar, 8gig of ram. nvidia 8800gts video card.
Reply 13 of 27, by Jorpho
I get it.
Does it work if you don't use the CD crack? Maybe you have a CD crack for the wrong version.
Thank you, it is an artistic piece of LabVIEW code.
Reply 14 of 27, by gow75
when it asks if you want to reinstall direct X 5 should i?
Reply 15 of 27, by leileilol
NO!
Reply 16 of 27, by gow75
so i got it to work without dosbox or nglide, but one issue when i start the game music doesnt work any way to fix that. also i am running the video in 640/480 so it works that way just no music.
Reply 17 of 27, by leileilol
There's no way to fix that in Windows 7. Windows 7 took out MCI CD audio functions.
Reply 18 of 27, by kolano
What about using XP Mode? I know that's not available for Windows 8, but it's present for Windows 7.
Reply 19 of 27, by gow75
MCI CD audio functions anyway to work around this? i havent tried using windows xp mode yet, i will try that.
