First post, by badmojo
The Mac Mini I've been using for a music server since ~2010 or so is dying - perhaps the waves of hatred I've been sending it ever since it arrived has finally gotten to it. I loved my iPhone so much that I had high hopes for it - I've always been a PC guy - but the hardware is slower than the specs suggest it should be, and the Mac OS really pissed me off. I installed Windows 7 on it and it was much improved, but now it's HDD is on the way out. I'd replace it but of course it's not just a matter of opening it up and slapping a new one it, it's complicated and not worth the effort.
So does anyone have a suggested setup for a Windows 7 machine who's purpose is simply to host a music server, and hold all our photos? It doesn't need to be fast, but I want general Windows navigation, etc to be snappy. On board video and sound will be fine. Quiet would be nice and it needs to be a proper PC so that I can upgrade / replace bits as required.
It doesn't need to look pretty, or be small for that matter. So I'll just grab whatever ATX case I can find that's cheap.
If anyone has some suggestions around the mainboard / CPU / RAM specs then that would be much appreciated.
Reply 1 of 3, by Jorpho
If that's all you need, it seems to me like you shouldn't even need Windows 7. A Raspberry Pi or some teensy Android device might well do the trick.
Reply 2 of 3, by BigBodZod
Have you looked at any of the Zotac or similar mini-ITX machines yet ?
You can get both Intel Atom and AMD APU models.
Newegg and other online vendors have a ton to choose from.
No matter where you go, there you are...
Reply 3 of 3, by bucket
Any Atom netbook or later will run Windows 7 just fine. I can't imagine what kind of space you'd need, but if sharing media is your hobby then you can't do better than network storage.
