First post, by FGB
After destroying my last PPro board with a faulty power supply I'm building a "new" Pentium Pro System gaming rig right now and want to put a ET6000/ET6100 card into it. The PPro 200MHz 1MB (black hat) is running at 233MHz on the top notch ASUS P6NP5 mobo.
I have both the Hercules Dynamite (ET6000, 4.0MB) and the infamous Apocalypse 5D Sonic (ET6100 2.0MB, PowerVR PCX2 4.0MB and ESS Agogo XP). When I run the usual benchmarks the Apocalpse shows abysmal performance.
In numbers it is:
9239KB/s VESA Speed (Readout with SpeedSys 4.78 ) opposed to 56857KB/s
94.7 fps in 3DBENCH opposed to 161.3 fps
12.1 fps in PCPBENCH (LFB) opposed to 23.0 fps
20.9 fps in PCPBENCH (NOLINEAR) opposed to 29.2 fps
A Trio64V+ card scores 29.2 fps in PCPBENCH (NOLINEAR), just for reference. Looks like this is the machines limit without tools like FastVid.
I guess something is very wrong here..
Of course the Apocalypse uses a couple of PCI-bridges on board, that may have an performance impact, but I never thought the ET6100 based card would be sooo slooow....
I appreciate any thought..
Kind regards from
Fabian
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
Reply 1 of 16, by F2bnp
I'm guessing you're not using FastVid are you? Definitely do that.
Reply 2 of 16, by FGB
I had aprox. the same difference in performance on a 586 platform and also on a 486 mobo, so I think this is not the issue. But I will try your suggestion. I know how FastVid works but why should it boost the scores of the Apocalypse 5D and not the Dynamite ? Thank you!
Reply 3 of 16, by swaaye
Maybe caused by video BIOS quirks? PCI bridge chips are certainly suspect too.
Reply 4 of 16, by FGB
Yeah sure, but "usual" BIOS quirks may cost 10% or so. . But this HUGE amount of bandwidth/performance lost seems to be another issue..
Reply 5 of 16, by swaaye
I suspect the bridge chips are affecting bus performance. I wonder how GUI performance compares.
Reply 6 of 16, by FGB
by this amount? I doubt this and wonder if these 2MB / 2.25MB cards lack any memory interleaving to profit from 4 memory modules instead of just 2 in the Apocalypse 5D.
Reply 7 of 16, by swaaye
I think most ET6000 cards use 2 memory chips. STB Lightspeed 128 usually came that way and it was praised for its DOS speed.
I would like to see how WinTune compares on your two cards, and look at what FastVid does in DOS too. Maybe also UniVBE.
Reply 8 of 16, by FGB
Yeah, you are right about the STB card. I already tested UNIVBE but it had no impact at all. I don't have Windows installed and my main concern is the difference of the two cards in the DOS environment. I will provide Windows results later, though.
Reply 9 of 16, by leileilol
I'd also like to know how SGL game performance compares too (since this card is two-in-one). Turok demo can be used with a benchmark parameter to give results.
Reply 10 of 16, by FGB
The card is actually three in one.. ET6100 for 2D, Nec PowerVR PCX2 for 3D and ESS Agogo for decent positional sound..
Reply 11 of 16, by FGB
No thoughts?
Reply 12 of 16, by sliderider
My ET6100 has sockets on it for 4 chips but only two were filled when I got it. Unfortunately, they use MDRAM and finding chips to fill the empty sockets without scavenging another video card for them is hard as hell.
Reply 13 of 16, by FGB
I've filled the sockets with 1.0MB chips to make it full 4MB,but there is no performance boost at all, because the memory bus of the card is 32-bits wide and MDRAM modules are 16-bits wide and there is no interleaving.
Btw. the MDRAM chips aren't that hard to find here in Germany.
UNIVBE doesn't speed things up and FASTVID is a non-issue because the slow DOS speed is platform and chipset independent.
Reply 14 of 16, by NitroX infinity
Two possibilities not yet mentioned;
1) The 3D chip is not running at the correct speed.
2) The card or chip is broken.
Reply 15 of 16, by Putas
Impossible without hardware mod.
Reply 16 of 16, by FGB
It is about the 2D core, the ET6100, and not the 3D NEC chip.. Of course the card isn't broken. It performs normal and has no quality issues, I just slow in DOS.
