First post, by Zup
- Oldbie
Hi, I was going to run some experiments in DOS and I've found that I've got no emulator for that. That's that I need:
- Accurate emulation. Not cycle accurate, but I need to choose a processor type (use only 8086 instructions, 80286, etc).
- Networking support. I want to check networking from MS-DOS, so a virtual network card is needed.
That's what I've found:
- Virtualbox (and VMWare, I guess) can do networking, but can not choose a processor type.
- PCem: Very good selecting a "target" hardware; no networking.
- DOSBox: Standard releases don't do "plain" networking, but there are builds with NE2000 support. But I don't know if I could select a 80286. Also, I need to boot from a disk image, because I need DOS using memory.
Does anybody knows an emulator that could be used?
