sliderider wrote:You should replace it with a different type of battery. You can solder a coin type battery holder to the old battery connector or even a AA battery pack. Those old barrel types are more prone to leakage and harder to replace when they go bad.
NO - DO NOT DO THIS! There is a current going from the motherboard to charge the accumulator. You have to solder a diode between the coin battery and the solder point (+) of the old barrel accumulator. If not, you may risk an explosion, an inferno, a desaster!
A safe way is to desolder or cut off (with a razor blade) the barrel type accumulator and to connect an external battery pack (3xAAA) to external battery connector. many boards work when you connect a coin battery holder (for 3V coin cells like CR2032) to the external battery connector.
Sorry, but it is a very bad idea to give advice without any clue. This is dangerous, man!
Cheers,
Fab
												www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
