First post, by Pingaloka
From what I've read in this article you can add some sounds to the Mt-32 so it emulates general midi GM.
What are your opinion on this?
Has anybody tried this?
http://www.houseofsynth.com/roland-mt-32-to-g … version-utility
Reply 1 of 4, by Mau1wurf1977
http://youtu.be/5NUQpAZeAdo?t=2h41m42s
My YouTube channel
Reply 2 of 4, by rfnagel
From this page:
http://www.rolandus.com/support/updates_drivers/general
MT-32 to General MIDI
This file contains a self-extracting archive that will rewrite the sounds of an MT-32 compatible device to the General MIDI sound arrangement. This file is compatible with the Roland MT-32, D-5, D-10, D-110, D-20, CM-32L, CM-64, LAPC-1 and other MT-32 compatible devices. This file also contains instructions in Microsoft Write format.
...this file:
http://cms.rolandus.com/assets/media/exe/MT2GM.EXE
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 3 of 4, by Malik
Pingaloka wrote:
From what I've read in this article you can add some sounds to the Mt-32 so it emulates general midi GM. What are your opinion […]
Yes, that's right. MT-32 and it's LA successors are quite versatile, in that, sysex patches can be uploaded into them. Game makers made use of this ability extensively to upload their own digitized samples like the water splash in King's Quest V, bird chirping sounds in quite a number of games, sea waves sounds, etc.
The GM patch set will set the instruments according to the GM specifications when uploaded into the MT-32.
I've never used it though, since I already have the SC-55 and CM-500.
