First post, by s997863
There's already a thread about connecting DOSBOX IPX to a real DOS PC, using Hal9000 dosbox build or NE2000 patch. There's also another talking about win98 but I couldn't find an answer there.
Is Hal9000's MegaBuild also applicable for connecting dosbox IPX to an old PC running DOS games on win98?
I've got DOS games running IPX LAN ok from the DOS prompts of 2 old win98 PCs (Doom, C&C, Mech2 Mercs ... etc). The 2 old PCs are connected via a switch. Neither PC is running real DOS mode, nor having any DOS drivers loaded (mouse, CD, IPX & sound all work ok from dos prompt nonetheless. None of these work if I "restart in MSDOS mode").
I want to add a new win7 PC to this network. I followed Hal's instructions for a new Win7 PC:
-megabuild 6 installed, IPX enabled & NE2000 set as instructed (all as per instructions except that I set frame to 802.3 because my real NIC cards work with this setting in win98 IPX protocol in the 2 old PCs)
-PCAP installed in Win7
-TCP/IP LAN is working ok between win7 and the old PCs (all connected on the switch. no firewalls, routers, or wireless)
-virtual NE2000 card configured in MB6 Dosbox & mapped to my Win7 PC's real ethernet card.
-IPX patch files mounted & loaded in MB6 Dosbox.
-I skipped Hal's win95 instructions. I don't have win95 installed in Dosbox and am just trying for LAN games, not for file/printer/internet sharing.
-Anyone know what steps to do next? What commands to connect the new (dosbox) & old win98 PCs? IPXNET startserver? Don't I also need to set some network address in Dosbox to match the other PCs' IPX network address in win98?
